configure fabric attach ports
configure fabric attach ports [port_list | all] enable | disable]
Description
Configures the Fabric Attach state per port.
Syntax Description
ports Specifies the port to configure.
port_list Specifies a list of ports to configure.
all Specifies configuring all ports in the system.
enable Specifies enabling Fabric Attach settings (default).
disable Specifies disabling Fabric Attach settings.
Default
All ports are configured to transmit and receive Fabric Attach attributed by default.
Usage Guidelines
Use this command to enable or disable a port from adding the Fabric Attach TLVs to the LLDP packet.
The following example disables Fabric Attach port 25:
# configure fabric attach port 25 disable
This command was first available in ExtremeXOS 31.3.
Platform Availability
